96' Accord alignment
Old Feb 15, 2003 | 07:02 PM
Blown383's Avatar
Blown383
Default 96' Accord alignment
I took my Honda accord to the alignment shop and had the car aligned. The problem was that the rear passenger side wheel was off by 3 degrees of camber and would cause the car to veer to the right. There does not seem to be any room for adjustment in the back however the tech said that the rear struts are leaking...and thats causing the camber change. Is he feeding me bull****?
-B
Old Mar 4, 2003 | 12:38 PM
stephan's Avatar
stephan
:exnbp:
Check the actual strut yourself. BTW are you lowered or anything? Do you have a camber kit installed? Feed us some more info.
Old Mar 4, 2003 | 08:44 PM
Blown383's Avatar
Blown383
The car is bone stock...its 100K old struts. I know its leaking but can it REALLY effect the camber by throwing it -3 degrees off ?
-B
