tire pressures
just wondering if anyone running scca stock classes has a general idea of what i should be running for front and rear pressures on a set of yoko all seasons on a 94 teg ls. ive been autocrossing for 2 years with an e30 bmw and i just about figured out the optimum tire pressures in it but that also took me a while to figure out... ran my first event this past sunday and i just couldnt seem to get the pressures right. for the most part i had the fronts down to 33 psi (and was afraid to go any lower) with a bunch of understeer, and about 36 in the rears. just wondering if you guys had any input.
thanks,
wes
thanks,
wes
you want to go the other way. higher up front lower in the back. it's different from the e30.
integra is fwd
integra is fwd
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
Actually you want more pressures in the front on most cars because when turning and braking you throw more weight to the front of the car which compresses the front tires.
I would start with 45 front and 40 rears since you are using all seasons.
Autocross Help Page
Autocross Help Page
On my lighter CRX I found good front grip with about 40 in the front with 195-60/R14 Azenis, I would think you'd want to go harder with soft sidewall all seasons and a heavier Integra like Mike said. Try chalking the sidewalls.
the e30 happens to be 4wd. its an iX, forgot to mention that. thats why i had the pressures the way they were, it also has some drive to the frond end, unlike the rest of the e30 bunch. i'll have to try the pressures you guys mentioned at the next event. im looking to get a better set of tires but it will probably wait until i get better dampers for now, a buddy of mine is looking to sell me a set of koni yellows. after i get those on the next goal will probably be to get a set of azenis on there.
