Leaning; bad?
Old Jun 28, 2004 | 06:26 PM
DakarM's Avatar
DakarM
Originally Posted by txhatch
I am talking about me leaning. I can fix car body roll.
no
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Jun 28, 2004 | 08:32 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
:doh: I guess its just a matter of preference... do what you feel comfortable with. If you had good seats and harnesses, your body would barely move at all... I personally think this is better, as it keeps the control interface consistent (i.e., you wont be scrambling for the shifter when youre leaning way over, and the steering wheel will always be in the same place), but again, thats probably more of a matter of personal preference.
Its also safer to be snugly strapped in to a well-bolstered seat. If you plan on competing much, I'd get used to being tightly strapped in... Ultimately its safer and better for driving. You may feel less compelled to lean if you sit more upright and closer to the wheel too. Most people's daily seat position is actually a bit too reclined. Sitting closer and more upright makes better use of the seat's bolsters, makes the seatbelts function better, improves your grip on the wheel and is a little better for visibility. But your body shape/size and driving preferences also factor in, so.... :dunno:
Old Jun 28, 2004 | 09:06 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Haha..i know, weird question.
I asked because corners feel more difficult then they are when i lean thus me not taking a corner as fast. I think my next hpde i will try not to lean see how it is. I am planning on replacing my srd with a non reclinable seat, harnesses, and a harness bar. Should plant me a little better.
Old Jun 29, 2004 | 03:14 AM
.RJ's Avatar
.RJ
Go Fast Crack Whore
Absolutely do not used a fixed back seat and harnesses without a rollbar.
Old Jul 8, 2004 | 04:59 PM
ED9man's Avatar
ED9man
driver
doesn't excessive body roll also cause some of the tires to do more work than the others?
Old Jul 8, 2004 | 07:32 PM
.RJ's Avatar
.RJ
Go Fast Crack Whore
Your front tires (especially the left front on track) already does more work than the others
Old Jul 9, 2004 | 01:08 AM
DakarM's Avatar
DakarM
the effect is minimal.
LCD Squad #0001
Old Jul 15, 2004 | 07:31 PM
babzy's Avatar
babzy
txhatch.
Something you may want to try at youre next Hpde event is putting a strip of masking tape at eyebrow level on the windsheild.Concentrate on keeping youre vision parallel to that strip,it will improve the lean factor and also help you look ahead.
Old Jul 16, 2004 | 01:56 PM
Poboy's Avatar
Poboy
Using your three point seat belt (unless you've gotten the roll bar), you can help plant yourself by moving your seat back one notch, buckling the belt, pulling the strap as tight as you can, jerk it quickly to lock it, then move your seat forward to the original position. That's what I (and many autocrossers) do to keep planted in the seat. I've even been able to get it tight enough I couldn't take a deep breath (do not do this).
Old Jul 17, 2004 | 02:21 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Thanks for the pointers. I already use the stock seat belt trick, helped a little. I think i will work on it next track day. Hopefully by then the car will have less body roll too.
