Help with numbers for tires
Old Oct 6, 2003 | 08:42 PM
lkailburn's Avatar
lkailburn
college kid
Default Help with numbers for tires
Hey i'm a noob when it comes to these tire numbers. could someone briefly explain the difference. thank you
Luke
(205/40/17) (215/45/17) (235/45/17)
Old Oct 6, 2003 | 08:44 PM
theguy386's Avatar
theguy386
I am tehguy... OH YEAH!!
First number is width, second number is sidewall height, and third is rim size
Old Oct 6, 2003 | 08:53 PM
DriftKing's Avatar
DriftKing
thats 95% right.
the first number is the width in CM. the second number is a percentage of the second number, which refers to the sidewall height, and the third is the rim size.
Old Oct 6, 2003 | 08:54 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Originally posted by DriftKing
thats 95% right.
the first number is the width in CM. the second number is a percentage of the first number, which refers to the sidewall height, and the third is the rim size.
fixed
Old Oct 6, 2003 | 08:58 PM
theguy386's Avatar
theguy386
i was just putting it in simpler terms. :bigok:
Old Oct 6, 2003 | 09:04 PM
DriftKing's Avatar
DriftKing
its all good brotha!!
Old Oct 6, 2003 | 09:09 PM
lkailburn's Avatar
lkailburn
college kid
hey thanks guys i appreciate. i'm assuming the third of the bunch is the best?? but would i be ok with the first of the three? will i see a big difference?
Old Oct 6, 2003 | 09:18 PM
DriftKing's Avatar
DriftKing
Default Re: Help with numbers for tires
Luke
it depends on the wheel and the car. the third (235/45/17) will only fit on a 17x7.5" rim. the others will just be roughly the same, but the 215/45/17 should have a stiffer sidewall than the 205/40/17.*
*Correct me if im wrong guys
Old Oct 6, 2003 | 09:21 PM
theguy386's Avatar
theguy386
Default Re: Re: Help with numbers for tires
:goodjob:
Old Oct 6, 2003 | 09:22 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The width is in mm.
Sidewall stiffness is dependent on the model of tire.
Generally to figure out what size rim to put the tire on, check out the manufacturer's specs. They will list a rim width range and a "measuring rim width." The measuring rim width is the size of rim you have to mount the tire on to actually produce a section with of whatever the specified size is.
