dsl help....
Originally posted by WiLL
can you rephrase that?
h:
you are basically saying cut and resplice all the wires that are going into the alarm. and splice everything back up so that it looks like how it did before the alarm was put in.
so im just taking the OG phone wires, and connecting them back with their OG colors.
thanks a lot man. what kinda of connects or splicing should i do? i never spliced wire so thin.
h:
h:you are basically saying cut and resplice all the wires that are going into the alarm. and splice everything back up so that it looks like how it did before the alarm was put in.
h:
blue/white>>>>red & blue>>>>green......cut those
in (2)
blue>>>black & blue/white>>>>yellow.....cut those
now connect the blues together & the blue/whites together & the alarm is no longer hooked in
connectors: goto home depot/lowes & get some similar to the ones you see there. if you can't find anything, strip the wire back about 1/4 inch & twist 'em together & elictrical tape each individually as a temp repair & hit me up & i'll send you some insulated connectors.
DON'T let the blue & blue/white touch or you'll short the line & lose dial-tone!!!
that's why you tape each individually
h:
h:
use your teeth :rick:
or a simple knife will do. remember to cut away from yourself!
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
i should try this.....tomorrow.
h: i hope i dont fawk up :doh:
Call from neighbors if need be
Originally posted by clickwir
if you do... call up the telco and have "wire maint" added to your line for like $4.... wait 4 hours and call em back up and tell em you have a wire problem.
wned:
h: im going to attempt this in a couple hours...or on monday when i come back home from my trip :happysad:will doing the old twist and tape method be ok for a few days? i couldnt find those connects at the store.
can you hook a brotha up:thumbup:
I don't know what you guys are complaining about DSL...Mines fast, was easy as shit to hook up, didn't interfere with our security system, and never went down.
The only problem now is that my dad wants to change local/long distance phone carriers to MCI...and I have to change to cable. So I have to arrange an appointment for the cable guy to come wire my house for cable and install a jack in my room. A lot more of a PITA than DSL fa sho!
