Reciever
Old May 16, 2003 | 07:49 PM
The Beav's Avatar
The Beav
i
Default looking for new home reciever
I need a new receiver for home the one i have isn't powerful enough and doesn't have digial optical input, i need something with:
  • At least 2 sets of digital optical inputs
  • At least 2 sets of RCA plugs input
  • 5.1 dolby or higher
  • dolby pro logic 2 support
  • preferably slim unit
  • speaker jacks for 6 speaker system (5.1) at least
  • powerful (ie at least 50 watts a speaker)
Old May 16, 2003 | 11:40 PM
97teg's Avatar
97teg
Usally recievers aren't used to power subs. Subs are usally powered. Its not slim but i really like my harmon/kardon 320 i think. It blows my high end (or used to be) kenwood away. Harmon doesn't rate thier power the same so don't dissmiss it cause it says only 50 watts. I will guarantee you those will be clean and hang with most others 100 watts.
Old May 17, 2003 | 12:00 AM
The Beav's Avatar
The Beav
i
ok yeah i didn't think about that on the subwoofer, do you know anywhere good to buy receivers online?
Old May 17, 2003 | 11:20 AM
97teg's Avatar
97teg
Well i have never bought anythign from these guys but they seem good and sometimes seem to have good deals. I think some stuff may be refurbished but just read and they will tell you if it is or not. I also like onkyo and denon. Any one would be a solid choice.
http://www.soundcity.com
Old May 18, 2003 | 02:30 PM
The Beav's Avatar
The Beav
i
i was looking at this one
Panasonic SA-XR25S
PRODUCT FEATURES
High-efficiency digital amplifier delivers 600 watts of power (100W x 6 @ 6 ohms, 1kHz, 0.9% THD), with exceptionally wide frequency response (10Hz - 44kHz +/-3dB), from a sleek receiver only 3 inches tall
Entirely digital signal processing and amplification achieves 98dB S/N ratio from digital input to output; compatible with sampling frequencies up to 96kHz for optimal performance with high-resolution digital sources like DVD-Audio and SACD
Comprehensive built-in surround decoding (Dolby Digital EX, DTS-ES, Dolby Digital 5.1, DTS 5.1, Dolby Pro Logic II, DTS Neo:6), plus powerful stereo mode
Component video switching allows you to select from two simultaneously connected devices using high-quality component video connectivity (e.g., DVD player and HDTV set-top receiver)
Sound Field Control adds complex acoustic signatures such as Club, Hall or Theater, for a richer listening experience
Digital synthesizer AM/FM tuner with 30 station presets (15 AM, 15 FM)
3 digital audio inputs (2 optical, 1 coaxial)
2 component video inputs, 1 component video output; 3 S-video inputs, 1 S-video output; 3 A/V inputs, 2 A/V outputs; 4 audio inputs, 2 audio outputs
Subwoofer preamp output with independent level control
Large, heavy-duty speaker terminals for front L/R speakers provide optimal signal transfer
5.1-channel analog inputs accommodate external surround formats such as DVD-Audio and SACD
Includes universal remote
PRODUCT DETAILS
SA-XR25S
Stereo Power per Channel
100W x 6
Front Surround Power per Channel
100W x 2
Rear Surround Power per Channel
100W x 2
Total Harmonic Distortion
.9% @ 1kHz, 6 ohms
Station Presets
15/15
Dolby Digital Decoder
Yes
DTS Decoder
Yes
Dolby Pro Logic Decoder
Yes
Simulated Surround
Yes
DSP Soundfields
6
5.1-Channel Input
Yes
Digital Inputs
Stereo Audio Inputs/Outputs
4/2
Rear A/V Inputs/Outputs
3/2
Front-Panel A/V Inputs
No
S-Video Input/Output
3/1
Component Video Input/Output
2/1
Composite Video Output
Multiroom Capability
No
Headphone Jack
Yes
Remote Control Type
Universal
RF Antenna Input
Yes
Phono Inputs
Yes
Preamp Outputs
No
Digital Outputs
1 optical
On-Screen Display
No
Product Height
3"
Product Width
17"
Product Depth
14-3/4"
Product Weight
10 lbs.
Warranty Term — Parts
1 year
Warranty Term — Labor
1 year
