'puter help
So the monitor on my mom's old laptop crapped out and we've got a working monitor plugged into the computer and we can't figure out how to get the new monitor setup as the default monitor (we're using logmein to access the computer). Windows xp home.
Any help would be very helpful.
not sure if the laptop is different, but right click on the desktop, click properties. then settings. then select the secondary monitor. there should be an option that says "use this device as the primary monitor". that's how it is on mine.
Function + F8 should switch it
Thanks for the suggestions, I'll try them when I'm over there next.
Typically the monitor function key toggles in sequence:
--Laptop monitor only
--Both monitors
--External monitor only
