how many and how much are motor mounts for a D16Y8? Is it something ez to do or should I have someone do it for me? Would that solve the vibrations that I have in my steering column?
EF stock have 4 mounts. However when putting a B-series into the small engine bay of the EF there isn't usually enough room for a front mount with the stock crossmember so a lot of kits only come with 3 mounts. However if you get an aftermarket crossmember you can fit a front mount on it, but you don't NEED it.
we used three mounts in my friends crx but we plan on putting in the front mount and a new crossmember. i believe having all four mounts helps combat wheel hop and tq steer.
