Math help please
Old Sep 30, 2009 | 06:44 AM
Red X's Avatar
Red X
x pǝɹ
Originally Posted by Line7
This is the other problem I need to solve, any insight on how to do it? Thanks for the help!
Monthly rainfalls in a tropical city are independents and normally distributed with an average of 60 cm and variance of 25 cm2, N(60,5). There is flood in the city if monthly rainfall exceeds 75 cm.
(a)What is the probability of having less than 50 cm?
(b)What is the probability of occurrence of flood?
(c)What is the probability that monthly rainfall exceeds 50 and no flood occurs?
(d)What will be the maximum monthly rainfall if probability of occurrence is 90%?
ok, this problem is relatively easy. I won't give solutions but I'll explain how to solve (I dont have the means or time to make calculations).
You first should graph what you have. You know its normally distributed, with a mean and a variance. Excel, Matlab, etc. can draw this graph for you.
a. the probability of having less than 50 is done by summing all the points from 50-inf and subtract that result from 1 (which is the area under the entire curve) and you'll get the probability for LESS than 50.
b. For a flood, you just sum from 75, inf and use that as the probability.
c. here you calculate probability from 50 to inf and subtract 75 to inf.
d. here you solve for when the probability is .9 (somewhere to the right of the mean)
Old Sep 30, 2009 | 06:46 AM
Line7's Avatar
Line7
Platinum Member
I have no idea how you did that. Can you explain what formulas you used ?
Edit: N/M, Awesome, thanks guys.
Old Sep 30, 2009 | 06:57 AM
Originally Posted by scotttharobot
i forgot how to do these almost instantly.
+1
Old Sep 30, 2009 | 07:24 AM
å's Avatar
å
åhhhhh
wow.. for a second i thought i stepped into bizzarro basement.
Old Sep 30, 2009 | 07:42 AM
Old Sep 30, 2009 | 08:02 AM
cpvdh's Avatar
cpvdh
bwahahaha, if you are struggling with the math aspect now you are in for a rough term
a) 0.02275
b) 0.00135
c) 1 - (0.02275 + 0.00135) = 0.9759 (between extremes a and b).
d) 66.408cm
I haven't taken statistics in 5 years so this could very well be wrong. I used a mean of 60cm, a standard deviation of 5cm (SQRT of 25cm2), and the fact that the data is normally distributed to solve these.
gf is applying at nsa for internship, fucking baltimore, why cant it be somewhere i can get a tan h:
Old Sep 30, 2009 | 11:42 AM
LABARINTH's Avatar
LABARINTH
Better Than Canada!
Default Help me solve this math problem.
Given the following.
196, 295, 394, 493, 592, Cheeseburger, 691
find Cheeseburger.
actually I know the answer I just wanted to see if anyone could solve it without google.
[SPOILER="answer"]689 h:[/SPOILER]
Old Sep 30, 2009 | 11:47 AM
Snoopy's Avatar
Snoopy
been there done that
is this thread in english? cause i dont understand any of it.
