Format?! I would if I had a CD. I got a legit key that came w/ the system, but no CD. If I'm going to go through the trouble...
Is there a folder called i386 somewhere on the C: drive? If so, that should be an image of the Windows CD. Burn it to a CD and use that to format and re-install.
There's like 20 of those folders. Which is the right one?
you probably have a recovery partition on your HDD....and sometimes there's a way to make a recovery CD (on Dell's there is). You can use that to reformat.
