Audio Crew v. Halp
I was asked to fix a problem with a karaoke set up at the local bar.
The problem is that when we plug the large screen TV in as a monitor, it causes audio feedback through the karaoke speakers.
Keep in mind, there is no audio going to the TV, only video.
The only things I can think of are to make sure the karaoke system is plugged in to the same circuit as the tv. And if that fails possibly rout the video through a VCR first, and then to the TV.
Any other ideas as to what could be causing it and/or what to do to stop the feedback?
It's more of a low hum. I don't know what kind of system it is, but i do know it happens on many different systems. We hire people to come in and do karaoke. The TV is always the same one, and other TV's work fine.
If it's just that TV it might be a grounding issue or it might be an indication the system isn't hooked up right. Isolation of the the TV somehow would probably get rid of the problem, so like you said connecting through a VCR or other component not so sensitive or a dedicated isolation device might help
