LT needs brakes thread (not ebrake cables)
Old Mar 29, 2008 | 04:37 PM
A-series's Avatar
A-series
v-card member alpha
Originally Posted by Snoopy
dont forget to check the ebrake
When I changed my pads I neglected to loosen the parking brake nut before I pumped the brakes back up to pressure (and then checking the adjustment naturally follows that) which you're apparently supposed to do h:
Old Mar 29, 2008 | 05:22 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I have been using Axxis Ultimates for a while now. They don't have any over-boosted initial bite, provide a firm pedal with easy modulation, don't squeal too much, and make a good amount of dust. Warm them up a little bit and they slow the car down right quick. With alacrity, even.
Apparently Carbotech Bobcats are the the be-all end-all of street performance pads but cost like twice as much.
Old Mar 30, 2008 | 07:35 AM
qtiger's Avatar
qtiger
I put Hawk HPS on the front and some random pads in the back on my wife's car. Works great.
Old Mar 30, 2008 | 07:44 AM
ISP James's Avatar
ISP James
DAMIMRED
i had Axxis on my integra and liked them....
they seemed to be relatively low dust and they clamped down nicely. i could go from real fast to stopped in a hurry.
i also had Brembo blanks and SS braided lines, for whatever that is worth...
Old Mar 30, 2008 | 07:51 AM
LT's Avatar
LT
The deer had to die!
Well I need better than random pads in the rear because my brake bias is close to 60/40
Old Mar 30, 2008 | 08:36 AM
qtiger's Avatar
qtiger
Ey, whatever works for you. On her car it's more like 80/20; the front rotors have well over twice the surface area of the rears. So I wasn't about to spend $80 on rear pads that don't do anything.
Old Mar 30, 2008 | 09:10 AM
LT's Avatar
LT
I was the same with the GSR. But the rears are bigger than the GSR fronts so $$$
Old Mar 30, 2008 | 09:11 AM
ISP James's Avatar
ISP James
DAMIMRED
ive never heard of any breaking distribution being anywhere near 60/40....
most are like 87/13 or at most 80/20
are you sure you arent talking about the weight distribution? h:
Old Mar 30, 2008 | 09:19 AM
LT's Avatar
LT
I read it somewhere, but I'm double-checking right now.
Old Mar 30, 2008 | 09:30 AM
LT's Avatar
LT
Okay, it is close to 60/40
A good read if you care http://www.mr2oc.com/showthread.php?t=41647
