Laptop replacement battery???
Old Jan 14, 2008 | 03:56 PM
jaymar88's Avatar
jaymar88
HA.net Workout Krew
http://www.batteries.com/index.asp?N...u=p%5Fprodcode
Old Jan 14, 2008 | 04:11 PM
DakarM's Avatar
DakarM
Originally Posted by Jani 5
about 70 cycles? :dunno:
200
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Jan 14, 2008 | 04:12 PM
Misa's Avatar
Misa
Pic Whore
Originally Posted by Brar
my battery has had 305 cycles... is it time to replace? :hsughr:
my 1st battery only held a 10 minute charge after 140 cycles. :dunno:
this new one is at 90% after 40 cycles.
DakarM's Avatar
DakarM
usually after about 400-500 cycyles the battery is worn out enough that it should be replaced. if it lasts less than 1hr then it's time.
LCD Squad #0001
Misa's Avatar
Misa
Pic Whore
Originally Posted by DakarM
200
i guess its different for every battery
Brar's Avatar
Brar
last I got a popup it said I'm at 77% or something, that was maybe a few cycles ago
Old Jan 14, 2008 | 04:13 PM
DakarM's Avatar
DakarM
you may need to reset the gas guage. disable power saving then charge the battery all the way, then drain it all the way, then repeat 2x. if your laptop has a battery conditioning available in the OS, then use that.
LCD Squad #0001
Old Jan 14, 2008 | 04:16 PM
Misa's Avatar
Misa
Pic Whore
did that.
trashed that battery a while ago
edit: and by trashed..... i threw it in one of those battery recycling bins on campus. h:
Old Jan 14, 2008 | 04:19 PM
DakarM's Avatar
DakarM
it depends on the type of battery cell technology used. if it's the standard li-ion cell using 18650 then 200 is about the half life.
if it's using smaller 16500 (i think that's right), then it will be less.
also if its li-polymer then it's again different.
ni-mh were the best at number of cycles, but of course they didn't last as long on a single charge.
LCD Squad #0001
