Vista gurus help...
Old Dec 19, 2007 | 12:54 PM
Default Vista gurus help...
How do I make it so Vista stops reading folders when you click into them?
How the toolbar gets a green process bar. How do I stop that so it stops reading the data?
PLEASE HELP!
Old Dec 19, 2007 | 03:38 PM
Misa's Avatar
Misa
Pic Whore
install xp.
Old Dec 19, 2007 | 03:42 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Originally Posted by Jani 5
install xp.
Problem solved h:
that's what I came in to say
Old Dec 19, 2007 | 03:46 PM
there should be a downgrade option when you throw in an xp disc.
Old Dec 19, 2007 | 05:18 PM
useless's Avatar
useless
i like cheese
install xp.
+2
Originally Posted by Epoch
Problem solved h:
same here
Old Dec 19, 2007 | 05:58 PM
Maybe I should install XP
Actually I was planning on doing that. There is a 10gig partition on the drive that has a "RECOVERY" title that I might install XP on.
how do you install multiple OS's and then choose when you boot up?
Old Dec 19, 2007 | 06:21 PM
Partition that shit
Or get 2 Harddrives h:
Old Dec 19, 2007 | 06:26 PM
I have a 80gig that is partitioned into 65 (Vista), 10 (RECOVERY) and a solo 500 that is data ONLY. No programs.
Old Dec 20, 2007 | 12:44 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
A grub will handle it. Not sure with XP and Vista if it includes a grub or if you need to set one up.
Serious answer: Hit escape.
Old Dec 20, 2007 | 03:09 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
If you are referring to the indexing of files, there is an option to turn it off somewhere in control panel. I'll find it when I get to work.
