Intercooler Water Sprayer Project Complete! (pics and vid)
Old Nov 4, 2007 | 01:12 PM
Pete's Avatar
Pete
Civilian
Default Intercooler Water Sprayer Project Complete! (pics and vid)
Yes, it is complete at last, after finally receiving the sprayer nozzles I sent out for and getting enough free time. The only problem I have is that I can't seem to get the nozzles to point downward toward the intercooler, but since they have a 360 degree spray radius, the fluid is still hitting it significantly. Here's some pics:
Here is the additional pump motor I installed on the reservoir:
There was another spot for it to fit nicely on there because I think the 02-03 STI models come with the I/C spray option and they use the same reservoirs as the standard Impreza models so that worked out well. All I had to do was drill a hole for the new pump and make sure it was sealed to prevent leaks. Here's a shot of the vacuum tubing going from the pump into the hood scoop duct:
Here's another shot of the scoop duct from the bottom so you can see the spray nozzles:
Also, a shot of the switch I rigged up to turn it on and off:
For the switch I just drilled a hole in the fake button that was already there and slid it in there. The button was probably the biggest pain in the ass because I had to run the wires from the pump and the fusebox through the firewall and under the center console. I am just glad that I got all the wiring right on the first try Finally, here is a video of the sprayers in action:
[YOUTUBE]NLygJpZZ3Ks[/YOUTUBE]
Hope you liked!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 4, 2007 | 01:16 PM
fathergoat's Avatar
fathergoat
:3
good job Pete, that's a clean install
Old Nov 4, 2007 | 01:29 PM
AP2's Avatar
AP2
Moderator Alumni
Nice job, however to make it cleaner I'd suggest you zip-tie the i/c tubing lines along with the washer fluid lines going to the hood
Old Nov 4, 2007 | 05:06 PM
Pete's Avatar
Pete
Civilian
Yeah, after looking at that second pic, I thought the same thing.
Old Nov 5, 2007 | 06:26 AM
Pete's Avatar
Pete
Civilian
Blah, some minor complications recently. I think the heat under the hood caused the vacuum tubing to soften a bit and it slid off one end of the t-fitting. I will go to home depot today and get some o-clamps to tighten the connections on the nozzles and the t-fitting just in case it may happen again.
spanky's Avatar
spanky
I go duffy on dem bitches
looks familiar
Old Nov 5, 2007 | 06:32 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Also makes a great Mexican shower.
Old Nov 5, 2007 | 12:01 PM
R_Squared's Avatar
R_Squared
LEVEL UP
schweet. I think my next ride might be a gently used WRX. :hsdunno:
Old Nov 5, 2007 | 12:09 PM
98CoupeV6's Avatar
98CoupeV6
:rofl: Good luck finding that. The ones I test drove that had over 50k miles on them all felt like they were ready to fall apart.
Old Nov 5, 2007 | 12:20 PM
fathergoat's Avatar
fathergoat
:3
that's like trying to find a gently used porn star
