Modified ink printer churns out electronic circuits
Old Apr 19, 2007 | 11:09 AM
Grifter's Avatar
Grifter
Default Modified ink printer churns out electronic circuits
* 18:24 18 April 2007
* NewScientist.com news service
* Tom Simonite
A standard office printer loaded with silver nitrate and vitamin C can produce (clockwise from top-left) mobile phone antennas, circuits, RFID chips and inductive coils on a range of surfaces (Image: IOP/University of Leeds)
Enlarge image
A desktop printer loaded with a silver salt solution and vitamin C has been used to produce electronic circuits. The UK researchers behind the feat say their experimental device could pave the way for safer and cheaper electronics manufacturing.
Being able to print out electronic components and whole circuit boards could provide an alternative to current manufacturing techniques, which are energy intensive and environmentally unfriendly.
Printing conductive polymer ink (see Goodbye wires and silicon, hello plastic chips), or pastes containing graphite or metal particles are two existing options. But researchers at Leeds University in the UK wanted to avoid the solvents needed for these processes.
PhD student Seyed Bidoki loaded a standard Hewlett Packard ink-jet printer with a solution of metal salts and water. After a pattern is printed using the solution, a chemical known as a reducing agent is then printed over the top to make solid silver form.
"We wanted to be able to use a totally water-soluble base," explains team member and chemist Matthew Clark. "That allows for much more environmentally friendly processes."
Metal ink
Bidoki loaded two separate chambers in the printer's cartridge, which normally contain different ink, with the metal solution and the reducing agent. Using silver nitrate solution as the "metal ink" and ascorbic acid (vitamin C) as the reducing agent proved the most successful combination.
He then programmed the printer to produce a variety of circuits and radio antennas on different surfaces including paper, cotton and acetate, all of which were placed in the printer like a normal sheet of paper.
"One test involved patterning an antenna like that used in a mobile phone on transparent film," says Clark. "It was possible to bend it almost in half without any loss of conductivity."
After a circuit is printed using silver nitrate, vitamin C is overlaid a few minutes later. Water can then be used to wash away other products, leaving the silver behind. Scanning electron microscope images reveal a rough surface of silver nanoparticles.
Join the dots
Printing the same pattern two or three times improves conductivity because it increases the number of contacts between silver nanoparticles. Desktop printers make images from tiny dots of ink that do not overlap, but bleed slightly into each other, explains Clark: "In future, we'd like to use an industrial jet printer that can so we'll need fewer passes."
Graham Martin at the University of Cambridge, UK, agrees that ink-jet technology could make new kinds of devices possible. But he says competing with existing technology could be difficult: "This concept are often simple but there are many challenges to meet. Creating a low enough resistance to match current standards is one of them."
But ink-jet printing definitely has a future, he adds. Currently, circuit boards and other components are made by etching the desired design out from a layer of metal, which is an energy intensive process. "Printing is an additive, not subtractive process, making it more environmentally effective," says Martin.
http://www.newscientisttech.com/arti...ine-news_rss20
Old Apr 19, 2007 | 11:50 AM
R_Squared's Avatar
R_Squared
LEVEL UP
that is pimp.
Old Apr 19, 2007 | 11:51 AM
fathergoat's Avatar
fathergoat
:3
sweet
