help me diagnose a motor problem *URGENT*
Old Mar 23, 2007 | 05:24 PM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
my guesses were the fuel related things too, but had no idea abt the timing issue... easy way to check tht would be to use a timing gun i guess?
Old Mar 23, 2007 | 05:32 PM
dubcac's Avatar
dubcac
I
That's ignition timing. You'd have to pull the valve cover, set the crank at TDC, and check to see if the cam gears line up with the TDC mark.
Old Mar 23, 2007 | 05:48 PM
aux's Avatar
aux
More Black on Black Crime
battery?
Old Mar 24, 2007 | 02:23 AM
R_Squared's Avatar
R_Squared
LEVEL UP
I'm having similar issues with my Integra and I'm 90% sure it's because I'm throwing a CEL for the ECT sensor...even though I already replaced it. h:
Old Mar 24, 2007 | 07:52 AM
Wharbone's Avatar
Wharbone
When was his last tune up?
Does it not start often after driving the car, but will start again in about 10 min. If so, it could be dry solder joints in the main relay. You can repair the main relay yourself, or buy a new one.
When it won't start up, can you hear the fuel pump turn on when the key is in the on position? Does it have spark?
