Car problem diagnostic?
Old Feb 13, 2007 | 08:47 AM
Tark's Avatar
Tark
Default Car problem diagnostic?
1995 Teg
a couple of days ago...I turn the key to start the car and nothing happens, no cranking, no noise nothing. The light go down... try a couple of times nothing. 5th try and it starts.
Now same problem but nothing to do it just wont start.
I changed the starter like 4 months ago cause i had the same problem. starter is still under waranty. Could it be the starter again?
Any other ideas? now it's sutck in a small parking lot, a towing cant get access to it so i will need to push it out of there but tomorrow it's going to snow 20CM and i will be more then likely snowed in :wtc:
Old Feb 13, 2007 | 08:51 AM
FDragger's Avatar
FDragger
the F is a secret :shhh:
maybe its the battery, try to jump it.
Old Feb 13, 2007 | 08:52 AM
Tark's Avatar
Tark
but if it was the battery how could it not even cran the first 5 time then all of a sudden start and i drove it for arround 200KM :thinking:
Old Feb 13, 2007 | 08:55 AM
connections?
bad ground...that could do it
FDragger's Avatar
FDragger
could be a number of things. maybe a loose connection somewhere. first step in diagnosing it would be to check the battery.
Old Feb 13, 2007 | 08:56 AM
Tark's Avatar
Tark
Originally Posted by rebeld
connections?
connection on the starter or on the battery its self?
Old Feb 13, 2007 | 08:57 AM
Tark's Avatar
Tark
i dont mind doing that but just seams like all the electric things still working in the car like fan, day light, cluster ect...
Old Feb 13, 2007 | 08:59 AM
check both...clean em up really good make sure tight.
also the ground cable and wherever that runs too
ive had it before where car would start right up then when i went to start it and leave it wouldnt...after 2 hours of monkeying i wiggled a cable and got a spark...cable was only getting partial contact so sometimes it would roll over and sometimes not.
Old Feb 13, 2007 | 09:03 AM
sherwood's Avatar
sherwood
I missed Sean
what kind of oil are you using?
Old Feb 13, 2007 | 09:04 AM
FDragger's Avatar
FDragger
you can also get a meter and ohm the negative battery cable to see if the connection is good.
