Crower 6 stroke engine
Old Jan 26, 2007 | 07:49 AM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Default Crower 6 stroke engine
http://www.autoweek.com/apps/pbcs.dl...THISWEEKSISSUE
Interesting except that the weight you eliminate through not needing a radiator is lost through having to carry water of equal or greater amounts :thinking:
Old Jan 26, 2007 | 07:53 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Sorry but its a repost
Old Jan 26, 2007 | 07:57 AM
custom s2000 engine in a midget car?
orly
Old Jan 26, 2007 | 08:27 AM
bnuk's Avatar
bnuk
if I remeber correctly this wasn't just a weight issue but but when the liquid water is sprayed in the hot comppression chamber it turns to steam allowing generating additional (free) power for the motor. Its more of an efficiency improvement.
Old Jan 26, 2007 | 09:14 AM
sherwood's Avatar
sherwood
I missed Sean
yeah, it's pretty much going to be the future of something... how long did we have to rest on our old 4-strokes before someone figured this out
Old Jan 26, 2007 | 09:34 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
“Especially an 18-wheeler, they’ve got that massive radiator that weighs 800, 1000 pounds. Not necessary,” he asserts. “In those big trucks, they look at payload as their bread and butter. If you get 1000 lb. or more off the truck…”
Gallon of water is about 8.33 pounds.
Big rigs hold 300 gallons of gas.
8.33 * 300 = 2499
2500 pounds added to the weight. Sure you can remove the radiator and all it's components, but unless they weigh more than 2500 pounds.... it's kind of useless.
Old Jan 26, 2007 | 09:37 AM
sherwood's Avatar
sherwood
I missed Sean
8.33 * 300 = 2499
what if the engine were to run on less gas, or get better mileage?
Old Jan 26, 2007 | 11:31 AM
useless's Avatar
useless
i like cheese
that's fricken
If it runs gas:water 1:1 you could cut the amount of gas in half and replace with water and when you remove the cooling system the weight difference wont be that big. Also removing the water pump will save HP on any car that uses a belt driven pump. Another advantage would be the change in aerodynamics, no radiator means you can close up the front of the car/truck. The engine could be smaller since it wont need water jackets.
This will be cool to watch and see what becomes of it.
Old Jan 26, 2007 | 11:48 AM
sherwood's Avatar
sherwood
I missed Sean
Originally Posted by useless
that's fricken
don't forget that if it is implemented in a forced induction engine the whole setup could work dual-duty as a water injection system as well... this would allow for lower octane fuel to be an alternative option in even high horsepower cars.
Old Jan 26, 2007 | 11:50 AM
F22B Prelude
Rachel Bilson
What if the temperature is below 32 degrees
