1995 water pump and timing belt.
Old Jan 16, 2007 | 04:36 PM
buddyv's Avatar
buddyv
Default 1995 water pump and timing belt.
How difficult is it to change a water pump, and timing belt on a 1995 Acura Integra LS 1.8? Is this something I can do, or are special tool required? Thanks
Old Jan 16, 2007 | 04:40 PM
catatonic's Avatar
catatonic
(´Д`)
It's a bit more difficult than posting in the correct forum or using a search button. You might want to find someone who's done it before to help.
Old Jan 16, 2007 | 04:53 PM
buddyv's Avatar
buddyv
The Do it yourself forum is closed; until your question is approved for posting.
Now, any special tools required for this job?
Old Jan 16, 2007 | 04:59 PM
2001TEGGSR's Avatar
2001TEGGSR
Simple hand tools, Jack, Jack stands, and if your not familiar with Honda engines you definitely need a helms manual.
If your changing the timing belt, this is an excellent time to replace the cam seals, tensioner, and inspect the oil pump main seal.
Old Jan 16, 2007 | 05:49 PM
buddyv's Avatar
buddyv
Thank you 2001TEGGSR. This is the info I need. I've worked on cars for years, and this will be my go on an Integra. Any other advice?
Once again thank you.
