C++ Help v.STD to System
Old Dec 6, 2006 | 06:21 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Default C++ Help v.STD to System
I don't know if theres anyone on HAN that knows much C++ or anything.
I'm working on a final project. My partner and I are making a calculator. I'm doing the dialog and hes doing most of the functions. The functions are using namespace STD while my dialog is using a namespace that Visual Studio made. I'm making my dialog with Windows Forms.
What I need to do is pass System::string to std::string and then std::string to system::string. Is this possible? Can anyone shed some light on this or toss out some code snippets?
Old Dec 6, 2006 | 06:37 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
I read somewhere that if I use this:
Code:
std::string my_string = "Some text";
System::String* string = my_string.c_str();
it should work. However my string is in the private section of a class. Normally I would just go c.get_ans() and it would return the string.
I tried
Code:
 System::String* ans1 = c.get_ans().c_str();
but it still says "error C2440: 'initializing' : cannot convert from 'const char *' to 'System::String ^'"
Edit: Nobody knows C++? Damn...
Old Dec 6, 2006 | 06:38 PM
Brar's Avatar
Brar
I remember when I wanted to learn C before 8th grade... I said fuck it one day in h:
Old Dec 6, 2006 | 06:39 PM
SHIT...i made a calc in C++ lemme see if i can find the program.
Old Dec 6, 2006 | 06:42 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
I tried making it with Windows Application but it was fucked up and screwy.
I'm going to have to see if my prof can shed some light.
Old Dec 6, 2006 | 08:18 PM
VPUPPY's Avatar
VPUPPY
c_str() returns a pointer to a constant. you are trying to initialize a non-constant variable to a constant. try setting the return value equal to a const variable to be used as a buffer possibly.
Old Dec 6, 2006 | 09:23 PM
mayonaise's Avatar
mayonaise
have you tried google?
http://blogs.msdn.com/slippman/archi...02/147090.aspx
http://msdn2.microsoft.com/en-us/lib...23(VS.80).aspx
http://www.google.com/search?q=conve...20std%20string
Old Dec 6, 2006 | 10:28 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
I've looked at those Mayonaise. Thanks though.
Can I have a const pointer, pointing to the string I need? Would that fly?
