anything stronger than WD-40
Old Aug 21, 2006 | 01:31 PM
G-M-W's Avatar
G-M-W
naw its the adjuster screw that u loosen to make my ground controls go up and down....the little hex bolt..its stuck
Old Aug 21, 2006 | 01:38 PM
G-M-W's Avatar
G-M-W
heres a pic
File Type: jpg
Old Aug 21, 2006 | 02:02 PM
pb blaster, and if that doesnt work, pb blaster and a torch. an unbeatable combo!
Old Aug 21, 2006 | 08:35 PM
pnthr30's Avatar
pnthr30
And if that doesn't work, PB Blaster, a torch, and some ice cold water out of a spray bottle. The dramatic change in temp. can/will really loosen up some rusted up bolts - although in your case, it might be overkill.
Old Aug 21, 2006 | 08:36 PM
RB's Avatar
RB
snitches get stitches
jb weld should loosen it right up.
Old Aug 21, 2006 | 08:38 PM
LT's Avatar
LT
The deer had to die!
I recommend a stick of dynamite.
Old Aug 21, 2006 | 10:33 PM
wedley2's Avatar
wedley2
bboy Wesley West
allen wrench combined with a socket to fit over the wrench.
or just hit it with a hammer.
Old Aug 21, 2006 | 10:38 PM
dubcac's Avatar
dubcac
I
PB Blaster or Liquid Wrench
Old Aug 21, 2006 | 10:42 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
PB Blaster.
I find it funny how people rarely realize that WD-40 means water displacement and it was the 40th formula they had tried. This means it is a water displacement tool first and a lubricant second
Old Aug 21, 2006 | 10:43 PM
AcuraFanatic's Avatar
AcuraFanatic
I found the problem. Sleeved coilovers. :down:
