Connecting 12v relay help
Old Jul 27, 2006 | 09:37 AM
flyromeo3's Avatar
flyromeo3
Default Connecting 12v relay help
I've done this before but I forgot the sequence.
Obviously the black wire connects to ground
the red goes to 12v constant from battery
yellow would go to equipment ( ex: 12v connection on amp )
blue goes to ignition / turn on lead.
The last time I wired a relay was in 2002 when i got my accord.
Old Jul 27, 2006 | 09:43 AM
rabidmonk's Avatar
rabidmonk
droppin the deuce
http://www.installdr.com/TechDocs/999403.pdf
last page
Old Jul 27, 2006 | 10:29 AM
flyromeo3's Avatar
flyromeo3
I found this one
http://www.type2.com/bartnik/images/relay.gif
Old Jul 27, 2006 | 10:41 AM
rabidmonk's Avatar
rabidmonk
droppin the deuce
as long as you've got your open/closed trigger correct, you should be fine
Old Jul 27, 2006 | 10:42 AM
flyromeo3's Avatar
flyromeo3
your post helped me out. Based on the information i read it seems as if im correct with the layout above. Thanks, if i fry my car ill be sure to let you guys know...lol
