What is honestly the difference?
Originally Posted by Brar
that's why you coat it
doesn't it release hydrochloric acid?
Dioxins are formed in virtually all combustion where the necessary atoms are available in the fuel. The formation of dioxins (and furans) requires presence of chlorine, heat, organic compounds and a catalyst. PVC can be a ready source for the chlorine in combustion for this process.Because chlorine can be found almost everywhere on earth (e.g., in salt), dioxin will be formed when most things burn, including wood, food, garbage and vinyl.
Originally Posted by OLDMAN
You could also build it out of mandrel bent 3" exhaust piping, and silicone sleeves or weld it together, and it does a better job of keeping heat out.
You really are a lost cause.
