hood is on and painted
I go duffy on dem bitches
Originally Posted by puffy
why does it look like different color white then rest of the car?
and the front cap (minus the hood) is spray painted. :hs:
Originally Posted by spankaveli
because the rest of the car isn't championship white yet.
Originally Posted by Omniscient
I think the front end will look good when it's fully painted. You should just leave it on.
warm butter on toast
i probably will. i'm just weighing my options right now. the right fender is cracked at the weld and i'm going to check with my friend and see how much he would charge me to re-do the fenders right (use full ek fenders and mod them to fit the door). also, the core support needs to be moved forward about 1/16 or 1/8 of an inch because everything doesn't line up perfectly...
So there EG front quarters with extra metal welded on?
the current fenders are 1/3 EK and 2/3 EG welded together.
