Honda-Acura.net (https://www.honda-acura.net/forums/index.php)
-   The Basement (https://www.honda-acura.net/forums/the-basement-2/)
-   -   POS starts, a month later POS doesn't start. (https://www.honda-acura.net/forums/the-basement/228875-pos-starts-a-month-later-pos-doesnt-start.html)
Omniscient Mar 18, 2006 11:59 AM
Well some of you might remember last November I recieved a DSMPOS 91 Eclipse that I traded a D16 header for. When I picked it up it ran. I drove it probably 3 times all winter because it wasn't that bad out. It sat since January. I tried to start it today to donate it to a friend and the battery was completely dead. We hooked up some jumper cables and it struggled for like 1/2 an hour then finally started. After he took the jumper cables off it died again. To me it sounds like a shot battery. Anyone else?
Edit~ The battery was purchased in November.
AcuraFanatic Mar 18, 2006 12:54 PM
Originally Posted by puffy
alternator or batt.
Mostly likely just needs a replacement battery. I just put one in the Vigor today. :happysad:
stephan Mar 18, 2006 12:59 PM
Get a voltmeter and test out how much voltage the battery is putting out. If it is above 10.45v it is a good enough battery to start the car. If not might try checking to see how much voltage the starter is putting out. Check ground wires from the battery as well :)
AcuraFanatic Mar 18, 2006 01:26 PM
That 10.45v rule they teach you is so stupid. There's varying amounts of voltage/amps needed to crank different engines.
But for a 4-cylinder it probably applies :oh:
stephan Mar 18, 2006 01:42 PM
It's just a no. the ASE likes to use I believe. We've found most 4 cyl's to be ok a little below that with our clip cars we have in lab :)
hitman619 Mar 18, 2006 04:09 PM
my bet is the battery...
fstop128 Mar 19, 2006 06:21 AM
91 probably due for a battery.
TeggerLS Mar 19, 2006 06:23 AM
if it won't idle without battery assistance the alternators probably shot, the alternator should have enough power to idle the car without any accesories running.
stephan Mar 19, 2006 09:23 AM
it won't even start :dunno:
TeggerLS Mar 19, 2006 02:49 PM
they said they got it started with jumpers but it died after they removed them. I think the alternator and battery need replacing.
© 2026 MH Sub I, LLC dba Internet Brands
