gasoline problems
Old Feb 17, 2006 | 05:16 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by AF
Your fuel economy should be improving, not getting worse. I/H/E all lean the fuel mixture out.
Your cars suck.
That's what I always thought...but in the J30A1 wouldn't the a/f ratio just stay constant because there's no MAF? Is that why my MPG decreases to sharply when it's colder out, because the fuel system compensates for the denser air by injecting more fuel? My engine sucks balls.
Old Feb 17, 2006 | 05:18 AM
Originally Posted by LT
Lay off the gas.
he's flooring it to hear the sucking noise. h:
Old Feb 17, 2006 | 05:33 AM
AcuraFanatic's Avatar
AcuraFanatic
I honestly can't give you a solid answer because I won't be learning about the sensors and all their technical purposes until next semester.
However, based on theory...no, it wouldn't. You have a MAP sensor if you don't have a MAF, and a MAP sensor reads intake manifold pressure, whereas MAF reads air flow speed.
Your pressure won't change when it becomes colder, the air does become more dense with oxygen but the total "density" of the air charge will not be affected.
Stock ECU's are able to fluctuate fuel demand to a degree based on climatic conditions but it's rather limited. Bolt ons will always lean the fuel mixture out. Running a little lean tends to make more power than running rich, but there's always room for improvement.
That's why I/H/E with K200, for example, makes a lot more power than just bolt ons without an ECU reflash.
Old Feb 17, 2006 | 06:16 AM
98CoupeV6's Avatar
98CoupeV6
Thanks Shawn. So why is my MPG 2-3 less when it's 20 degrees compared with 50 or 60?
Old Feb 17, 2006 | 06:54 AM
AcuraFanatic
Colder air only benefits an engine to a point. I think below freezing it begins to have the opposite effect.
Old Feb 17, 2006 | 07:39 AM
You should look into one of the Turbonator things. It will increase your mpg by 35% and give you mad power yO.
Old Feb 17, 2006 | 07:59 AM
THEOLDMAN's Avatar
THEOLDMAN
Checking it twice
Originally Posted by dubcac
There's nothing wrong with your car. Lay off the throttle.
That sounds logical to me.
Old Feb 17, 2006 | 07:25 PM
ED9man's Avatar
ED9man
driver
Mine won't get worse than 28 no matter what I do.
With no VTEC for a week though, I noticed that I got an extra 60 or so miles out of a tank. h:
Old Feb 18, 2006 | 11:59 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Originally Posted by janiVI
95 ls
LS=B series. B18B or A? can't quite remember, but if you did have an MAF, which you don't, it would most likely be located on the intake.
Old Feb 18, 2006 | 12:02 PM
RB's Avatar
RB
snitches get stitches
It's the MAF.
