should i change the battery when replacing starter
Old Dec 29, 2005 | 08:03 PM
sinthetiq's Avatar
sinthetiq
Default should i change the battery when replacing starter
.. so im going to replace the starter on my moms sienna tomorrow.
should i get a new battery? anything else i should replace while im working on it
Old Dec 29, 2005 | 08:08 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Why would you need to replace the battery when you're replacing the started?
Old Dec 29, 2005 | 08:09 PM
sinthetiq's Avatar
sinthetiq
:dunno: heard from someone that its advisable that i do? i was wondering the same thing.. thats why i posted
Old Dec 29, 2005 | 10:28 PM
S2Kev's Avatar
S2Kev
Nah, it should be ok.
Old Dec 29, 2005 | 11:16 PM
XSrcing's Avatar
XSrcing
no. just make sure you disconnect it.
Old Dec 29, 2005 | 11:21 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Was it the guy at the parts counter?
Change the starter and use the old battery unless it is junked.
Old Dec 30, 2005 | 01:51 AM
sandstorm's Avatar
sandstorm
don't waste ur money ..... changing battery is extremely easy and do it when u need to
Old Dec 30, 2005 | 06:51 AM
fstop128's Avatar
fstop128
some people change the battery when they replace the alternator..alternator can over charge/drain the battery when it goes bad..
Old Dec 30, 2005 | 07:25 AM
stephan's Avatar
stephan
:exnbp:
Check the battery terminals and make sure they are both clean and do not have sulfation on them. Use a voltmeter and check how much volts the battery can produce. 12.45 volts is what the minimum spec for a 75% charged battery is according to ASE. If you want you can bring the battery to a car store to get load tested.
