makin a website.. need help
Old Oct 12, 2005 | 02:13 PM
sinthetiq's Avatar
sinthetiq
Default makin a website.. need help
hello. i need to make a website, but would like some assistance
1) i have a layout in photoshop that i'm going to need to make in html or whatever
2) there are going to be a bunch of pages
3) how can i have those pages call the layout format, that way if i were to change something on the layout, i wouldnt have to go on each and every page
k., thanks in advance
Old Oct 12, 2005 | 02:14 PM
Misa's Avatar
Misa
Pic Whore
use css?
Old Oct 12, 2005 | 02:15 PM
sinthetiq's Avatar
sinthetiq
examples/tutorials would be helpful
Old Oct 12, 2005 | 02:27 PM
no idea.. i go and change it on every page h:
but yeh, you have to use style sheets or somethin like that.. css sounds about right
Old Oct 12, 2005 | 02:34 PM
sinthetiq's Avatar
sinthetiq
i know how to use css/stylesheets to edit the fonts/colors/etc.. but how can i use css to arrange a format/layout
Old Oct 12, 2005 | 02:50 PM
mayonaise's Avatar
mayonaise
Originally Posted by janiVI
use css?
yup. CSS is your best bet, and it's really useful. it's a little tricky at first, though.
there should be zero or minimal "layout" in the HTML itself. so no colors, spacing, etc. leave that all to the CSS. everything that might need to be moved, sized or styled differently can be placed inside a <div></div> or a <span></span>. each HTML element can be given a class and an id. an id has to be unique throughout the entire document, but a class can be reused in different objects. you can then use CSS to apply styling to each individual object by ID, or to a class of objects by class. does that make sense?
this site has a decent tutorial section. there are plenty of other CSS tutorials if you look for them.
http://www.w3schools.com/css/
Old Oct 12, 2005 | 02:57 PM
sinthetiq's Avatar
sinthetiq
is it possible to have a menu within the header... im familiar w/stylesheets, just dont know how to begin w/creating a header (separate from the page) so that i can edit the header/menu without having to change each and every page. if that makes sense.. if i wanted to add a link, i would only edit one page
Old Oct 12, 2005 | 03:13 PM
sinthetiq's Avatar
sinthetiq
blah, i could use
Code:
<? include("header.php")?>
but i realized the layout's going to have a column as well. so i would have to have one layout..
i cant find any resource that shows an external css layout/format ..
Old Oct 12, 2005 | 03:42 PM
mayonaise's Avatar
mayonaise
Originally Posted by sinthetiq
blah, i could use
Code:
that piece of code is PHP, which is a server side scripting language. if you can use php, that would be a good solution to your problem. you could still have "a column" as a separate file, depending on what you need to do with it.
Old Oct 12, 2005 | 03:53 PM
sinthetiq's Avatar
sinthetiq
yah, i ended up jus using 3 separate includes thanks
