lug nut question
Old Oct 5, 2005 | 05:38 AM
pnthr30's Avatar
pnthr30
Default lug nut question
What is the difference between Acorn Bulge Seat and Acorn/Tapered Seat? Which one do I need/want? I am looking to get some black lugs for the winter wheels I am putting on (99 Teg). Please see the link below for a better understanding of what I am talking about.
http://www.brandsport.com/golugnufor122.html
Thanks a lot.
Old Oct 5, 2005 | 05:42 AM
yellowbastard's Avatar
yellowbastard
Bootyologist (__i__)
The only difference I see is at the bottom of the lug nut. It has a slightly different shape.
Old Oct 5, 2005 | 05:43 AM
pnthr30's Avatar
pnthr30
Does it matter which one I get? Will both work/function the same? I don't really see a big difference, but I want to get whatever one is "correct."
Thanks
Old Oct 5, 2005 | 05:44 AM
LT's Avatar
LT
The deer had to die!
the acorn bulge seat will make contact with more surface area. the acorn tapered is good for smaller lug holes.
Old Oct 5, 2005 | 05:46 AM
pnthr30's Avatar
pnthr30
I am putting on 14" steel wheels from an older Teg (94-97)......so I want the bulge seat, correct? What would be considered a smaller lug hole?
Old Oct 5, 2005 | 05:48 AM
yellowbastard
With steelies you won't have a problem with either. But if you had aftermarket wheels then that would be something you would need to worry about.
Old Oct 5, 2005 | 05:50 AM
pnthr30's Avatar
pnthr30
Thanks guys! I didn't think it mattered much with the steelies, but I wanted to make sure.
Old Oct 5, 2005 | 06:08 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
For OEM wheels you want acorn/ball shaped lug. Most aftermarket wheels use conical/tapered seat lugs.
Autocross Help Page
Old Oct 5, 2005 | 06:18 AM
pnthr30's Avatar
pnthr30
Thanks again, guys! Bulge it is.
Old Oct 5, 2005 | 06:25 AM
Just don't go to the auto parts store and ask if they have bulging nuts. :uhhok:
