Brembo GT Brake Kits
First thing I'd do is upgrade your pads and fluid, then either resurface or replace the rotors. See how much of an improvement that gets ya, then worry about big brakes.
And if that turns out to be not enough, take a good look at Stoptech. They make awesome brake kits and are more affordable than Brembo.
Originally Posted by tony
your gf?
h:
h:
h: I wish.. just some Taiwanese broad that is cute.
cha' with everything everyone else said, only point of big brake kits is to have more surface area for better cooling and less concentrated areas of heat, not to reduce 60-0 ftages.
Best way to reduce those is with high grip tires, good bleeding, new fluid, new rotors (general maintenance kinda stuff.)
h:
