Expert Electronic Help NEEDED
Old Jul 19, 2005 | 06:19 PM
95 SOL's Avatar
95 SOL
Banned
Default Expert Electronic Help NEEDED
Ok, I have a big hobby messing with electronics...my new project that i've been working on now is using a walkie talkie with a small modification to set off a model rocket. In theory my idea works...but i don't see why it's not when i put it to the test...
What i've done so far:
Removed speaker from one walkie talkie
Soildered new leads off of the positive and negitive and sent them through the casing of the walkie talkie.
Connected the new leads to a small model rocket fuse. (the wires should only get hot when the signal would get sent to the speaker...thus when you call the waklie talkie...
The problem i'm having is i think theres an inverter in there becuase i'm not getting a DC signal off the new HOT leads i'm getting 1.4VAC.
I need to figure out if i shoudl use a relay or a transistor to use an alternate power source like a side mounted double A battery.
Any help appreieated thanks.
Old Jul 19, 2005 | 07:14 PM
sherwood's Avatar
sherwood
I missed Sean
i could help you but i'm not about to tell you how to make a wireless detonator...
note: i think many would agree it's a bad idea to share these ideas with someone we don't know...
Old Jul 19, 2005 | 07:21 PM
Nelson's Avatar
Nelson
Administrator
You want a walkie talkie to set off a rocket.. .. WTF are you trying to do.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
