transmission case swap problem!!!!!
i swap my transmission housing, and moved the gears from one transmission to another transmission because the housing on the other tranny was broken. so im just swapping tranny housing. i took the gear out and put it on the other tranny but im not sure if i did it right. i took a little less then half the gears apart..im like 80 percent sure its right but then again im not sure. the other problem is the casing, when i try to close back the casing. it would not close all the way in. theres like a half an inch space left. i dont know why it would not close. what i think the problem is that. the tranny i had was a 94 gsr tranny. that says ysk1 swapping into a ysk 2 gsr tranny. will that have anything to do with the cover not closing? does anynoe know where i can get a transmission diagram or can someone give me some resource...thanks
you seem nervous or worried... i had no clue what you were babbling about until the last couple sentences. until then, i kept getting confused thinking i was reading the same sentence over and over again.... then i realized you were just repeating yourself. the same sentence over and then i realized you were just repeating yourself.
The 2 housings are identical...you did something wrong. I hope you have a manual.
