Wireless network problem
speaking from personal experience? :reechy:
h:
Originally Posted by 95SiR
kinda. reechy was telling me how that happens to him sometimes...so i guess its kinda from personal experience since i personally heard about someone's experience
h:
h::rofl: erages
If you are having irregular wireless connections, you can help by checking the following factors, all of which can greatly affect your wireless signals:
1. 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default is 6) and restart the wireless computers. Consult the router’s documentation or see Answer ID 470 if you are unsure on how to do so.
2. Physical obstructions: Your router or wireless computers may be loosing connectivity because of physical obstacles, including walls and floors. Try to physically move the equipment to different locations to find a better link.
3. Placement of the router: Linksys suggests that you place your router as high off the ground as possible. If placing in a high location, be sure to give leave a distance of 2-feet between the router antenna tips and the ceiling and wall. If your signal goes through multiple floors, try to place the router on the upper-most floor, and up high in the room that it will be placed in.
4. Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Author:
KBRS
Copyright © 2004 Cisco Systems, Inc.
that about sums it up
Author:
KBRS
