Transmission help
So yesterday I pull my transmission because I am going to send it out to get rebuilt. I call up the place that I think I am going to get it rebuilt at, gear speed, because I have a JDM box and I think they have all the parts to fix it. They tell me that they can't replace bad gears because it's impossible to get Japanese gears but if the gears are bad they can use "A1" gears, I'm assuming they meant B17A1. So are all the parts the same except the gears to an 92-93 Integra GS-R? If so can I get it rebuilt cheaper locally and just tell them it's a 92 GS-R transmission and just buy the carbon syncros that I want to use from that place? Or are there other things I have to consider or other parts that are different? I am a little stuck on what to do.
Well apparentley nothing is interchangable, and all they can do is sleeves, forks, and syncros, seems a little pricey for a $1200 rebuild without shipping. I'd rather get the parts and have a local shop do it, but if the gears are bad it's not even worth it. I think I'm going to have to find a 92-93 GS-R tranny or convert to hydraulic and get a newer one. Those are super hard to find too and I'd have to put my LSD in it. I don't know what to do now, I don't know if a newer B tranny and hydro conversion is even in my budget, and if it'll accept my LSD that I paid for, and I don't even know if it'll be good because it's used, I don't want the same thing to happen again. This sucks, I don't know what to do, I guess I'm going to have to pull it apart and see what it looks like.
I find it hard to believe that nothing is interchangeable, because it's "JDM". The parts should still be interchangeable. However, a USDM B17 tranny would have shorter gears. Check this out, a list of gear ratios for different trannies.
http://www.hondaswap.com/forums/inde...howtopic=29829
Originally Posted by ED9man
Do you anywhere good to look for a used B17A1 transmission?
I promise you that you'll never find one in a junkyard. I've only found one G2 GS-R in a yard and it was damn near completely stripped (the final owner scrapped the shell after salvaging the engine and trans.)
Do all ITR transmissions have factory LSD? What do I need to do to make my cable clutch car accept a hydraulic ITR transmission? The one on ebay was an SiR II and I really don't want to risk buying another junk JDM transmission I can't rebuild. I'm still looking for a 92-93 GS-R transmission. This sucks, I should have a transmission shop inspect mine to see what's wrong with it, if it's only the parts that can be replaced I think I'll have it rebuilt, but if stuff that can't be replaced is bad, it's not repairable. I hate this shit. :madfawk:
the LSD in your Y1 won't fit a Y/S80 (g3 Integra) tranny.
yes, ITR transmissions are LSD-equipped from the factory. i don't know the slightest thing about converting cable to hydraulic.
you'll need different linkages and mounts. all b-series transmissions will bolt to b-series blocks. don't know about the clutch, it should use the same.
i have a 95 GSR tranny that could use a rebuilding :rick:
