XP to XP Pro?
We can’t vouch for this hack, because we are too lazy to try it (and we never, ever violate copyrights or EULAs), but kind reader Martin explains the process for turning an Windows XP Home install disc to a Windows XP Pro disc after the jump.
It sounds pretty simple to do (just some registry changes), but you can’t install Service Pack 2, so you might try to slipstream in the changes to your modified install disc (if that’s even possible).
Alternately, buy XP Pro, or get a Mac.
so who has done it?:thinking:
yes indeed, you can’t change an installed Windows but only your Installation CD (or even a recovery CD in case the manufacturer had not left out important parts)
Here’s the detailed breakdown you asked for.
1. Copy the root directory and the i386 directory of the WindowsXP CD
to your harddisk
2. Extract the Bootsector of your WindowsXP CD
3. Change 2 Bytes in i386\Setupreg.hiv :
a) Open Regedit
b) Highlight HKEY_LOCAL_MACHINE
c) Menu: File -> Load Structure -> i386\Setupreg.hiv
d) Assign an arbitrary name to the imported structure e.g. “Homekey”
e) Goto HKEY_LOCAL_MACHINE\Homekey\ControlSet001\Services\ setupdd
f) edit the binary key “default” and change “01” to “00” and “02” to
“00”
g) Highlight “Homekey” and select menu: File -> unload structure
4. Burn your new XP Pro CD
5. Install WindowsXP as usual. Your XP Home Key will work.
Note: You cannot apply SP2 to such a WindowsXP Pro, so step 1.b)
might be to integrate SP2 in your Installation CD
Please check the menu-entries as I don’t owe an English copy of
XP and have to guess them.
to your harddisk
a) Open Regedit
“00”
Originally Posted by click sidious
:dunno: I just start with XP Pro Corporate right from the start. None of that stupid 'activation' mumbo jumbo crap.
I can't see how XP Home and XP Pro are remotely the same. XP Pro has so much other software like Terminal Services and don't even get me on the 50 services that are open including RPC which causes XP to shutdown if you don't patch your system.
I wouldn't try it, don't seem to safe.
all youre "really" doing is changing the product ID. I doubt M$ would include pro-specific features on a home cd.
