So I did an oil change and transmission fluid change yesterday....
Old Mar 6, 2005 | 01:48 PM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
Default So I did an oil change and transmission fluid change yesterday....
and everything went well until i got to the transmission. The bolt was seized on the bottom of the transmission so i couldn't flush it. So i had to vacuum it out and well that took forever. Stuff was black and smelly but now after the change with near gear oil it's nice and smooth.
Old Mar 6, 2005 | 01:52 PM
Anthony's Avatar
Anthony
oh btw how do you get out a seized bolt? pissed me off because i even tried using a breaker bar and no budge from the bolt and it almost killed my tools
Old Mar 6, 2005 | 02:15 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
You worked on the 240 I presume. As for the bolt... Umm... Liquid Wrench?
Luckily on Hondas the drain bolt is easy to find and the fill hole is under the VSS
