Wireless Connection Issues...
Old Mar 1, 2005 | 07:13 PM
dubcac's Avatar
dubcac
I
Default Wireless Connection Issues...
I've been having trouble with my wireless connection the past few days. It has been fine lately, and fast...however, the past few days it has been lagging like crazy, and in my wireless utility showing a speed of 1-2 Mbps. It usually is connected at 48 or 54 Mbps. I still have a 100% signal to the network as shown by the wireless utility, and the antenna has not been moved...still has good signal. The speed will go up to 48, then down to 36, 24, 12, 5.5, 2, and finally 1. Any ideas?
Old Mar 1, 2005 | 07:14 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Try resetting your base station. It happens to me every once in a while.
Old Mar 1, 2005 | 07:21 PM
Misa's Avatar
Misa
Pic Whore
change the channel
Old Mar 1, 2005 | 07:42 PM
dubcac's Avatar
dubcac
I
Reset the router and that did the trick...for now.
Old Mar 1, 2005 | 07:46 PM
sherwood's Avatar
sherwood
I missed Sean
resetting it just finds the clearest channel hlaf the time, change the cannel... someone prolly bout a wireless router wround you or a new wireless 2.4 ghz phone
Old Mar 1, 2005 | 07:47 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
I've your registering 54Mbps speeds, I'm assuming it's an 802.11g setup. It's possible some of the performance drop is coming from an older 802.11b device attaching to your network (if the two are used together, the router must slow everybody down to 11b's 11Mbps to make it work). I'd say time to change the SSID channel and change your WEP key (or start using one) if not WPA.
Old Mar 1, 2005 | 07:48 PM
dubcac's Avatar
dubcac
I
Yes we have a G setup, and we run WEP...nobody else is connected to our network, and none of the neighborhood networks run on our channel. It was slowing down way past 11Mbps...down to 2 or 1.
