So to get in, if I read this correctly, you'd just hit the 4th bottom from the top, then the 2nd, then the 3rd, then the first? (assuming its in a verticle arrangement)
Same goes if there's like 10 things to choose from right? You only care about the top 4....
correct.
if the coke machine has 4 choices across, it might be the horizontal config. so try that if the vertical config doesn't work.
