Crazy gains for $400 from an F23 block
Originally Posted by Booba Fettish
F23 block with a H23 head
so F23 block with H22 head? I glanced at it and couldn't figure it out :chuckles:
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
he's not playing, it's a frankenstein motor to the fullest.
1993 H23A1
head (modified combustion chambers), intake, distributor, wiring harness, timing belt components
2001 F23A5
block (bored to 87mm), crank, rods, alternator bracket, head gasket
1998 H22A4
pistons, pins, rings, rear engine mount
1993 H22A1
injectors, crank pulley, alternator, front engine mount, ignition coil, flywheel
1991 F22A1
water coolant pipe to mate with the H23 intake
199? F22?
left engine mount
199? D15?
ecu (modified)
"other"
red baron intake manifold gasket, mild steel H23 DC primaries, stainless H22 DC secondaries,
ebay intake, super tech oil filter, permatex grey silicone and copper gasket spray, etc.
2001 F23A5
1998 H22A4
1993 H22A1
1991 F22A1
199? F22?
left engine mount
199? D15?
ecu (modified)
"other"
