PC problem: reboot after display properties changed.
Old Nov 17, 2004 | 10:05 PM
Veto's Avatar
Veto
Default PC problem: reboot after display properties changed.
Hi,
I just built a system for a friend (1st build for me) and I seem to have run into a problem. I put together the following system for him:
P4 2.4A 533 Mhz FSB
ASUS P4S800 board
512 PC2700 memory
3 fans
Thermaltake 420 Pure power PSU
Seagate Ultra ATA 200 Gb HDD (7200 rpm, 8mb cache)
GIGABYTE ATI RADEON 9250 Video Card, 128MB DDR, 128-Bit, DVI/TV-Out, 8X AGP, Model "GV-R925128D"
Problem: After the build, everything runs just fine EXCEPT when i try to change the display properties to a higher resolution, say: 1280 x 1024 @ 32bit, the PC reboots immediately. I was also not able to playback any DVDs even after the proper software and codecs had been installed. I would appreciate it if someone could point me the right way as to what the problem might be & maybe provide a solution. TIA
Old Nov 17, 2004 | 10:11 PM
Im@ge's Avatar
Im@ge
So ugly it hurts..See?
well..we could trade computers and I could get the problem fixed :dunno:
Old Nov 17, 2004 | 10:15 PM
HawtPants's Avatar
HawtPants
the one and only
dvd software players dont require codecs. i use powerdvd :dunno:
Old Nov 18, 2004 | 05:47 AM
Veto's Avatar
Veto
Thanks but it's not mine to trade and this thing weighs a tonne....the case alone is almost 30 pounds. h:
Originally Posted by DĒvi-Wan Kenobi
dvd software players dont require codecs. i use powerdvd:dunno:
Yeah, in my haste I meant, I've tried all types of video and that includes DVD as well. I installed the codecs for other videos eg: Fansubbed Anime etc. I installed PowerDvD on his machine too.
I just noticed this , it doesn't even allow you to choose a lower resolution setting. I've even tried installing new up-to-date drivers and uninstalled the old driver completely. Still, same problem. Should I just RMA this and get a different one? Any help is appreciated and thank you both for your replies so far.
Old Nov 18, 2004 | 05:54 AM
reno96teg's Avatar
i'm pretty sure powerdvd installs a decoder..
anyhow, veto.. apparently you've updated the drivers. how about the bios? have you installed the chipset software? have you reseated the cards? try this. are you against doing a reinstall of everything and starting with the latest drivers? i'd try this as well if all else fails.
Old Nov 18, 2004 | 05:57 AM
spanky's Avatar
spanky
I go duffy on dem bitches
video card drivers?
Old Nov 18, 2004 | 07:34 AM
Veto's Avatar
Veto
Originally Posted by spankaveli
video card drivers?
Yup, upgraded to the latest 4.11 drivers from ATI.
I think re-installing everything is the only option left. I've reseated the cards last night and that didn't do any good. Same with BIOS, everything is fine there. Anywho, I gave him my card to use for now, and it seems to work fine. I'm gonna try and play around with this cad on my PC to see if anything changes. Thank you all for your help.
