gas smell
Originally Posted by wedley2
after changing my dad's fuel filter (and about 1 gallon of gas spilled all over the floor) i washed the engine bay, problem solved.
make sure u torqued down all the bolts.
h:
Originally Posted by ED9man
Yeah I got the pressure out of the system first so it was just a little bit that dribbled out onto my hand. Then I was dumb enough to pour the fuel back into the tank not realizing that I dumped some of the junk that was in it back in too, it was like milky color.
h:
h:
Originally Posted by Tobra
I thought the SS thing only worked for the garlic smell. Try some smelly lotion or toothpaste, that is how I used to wash the formaldehyde smell off after cadaver lab.
Gojo goo will take anything off with enough rubbing. It'll evan take oil out of your clothes, if you put some of it on the stain right after it happens. I used to use that stuff all the time cause it is non-abbrasive, when I worked in a printing factory. -For Ink that is.
