simple question(to a few)
Old Nov 4, 2004 | 02:08 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Default simple question(to a few)
what would happen if one were to put diesel fuel into a car that has a gasoline engine? this is a serious question, how bad would the engine's damage be?
Old Nov 4, 2004 | 02:10 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
DANGER TO MANIFOLD
YOUR FLOOR PLATE WILL FALL OFF
jkjk. Since Diesel combusts naturally under pressure, I'm guessing it would ignite before the spark.
Old Nov 4, 2004 | 02:14 PM
ED9man's Avatar
ED9man
driver
It would destroy your fuel system to begin with I bet.
Probably screw up your engine's internals too because it doesn't have the same combustion properties as gasoline. Probably combust at the wrong time in the engine cycle.
Old Nov 4, 2004 | 02:15 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
aren't diesel engines higher compression than regular gas though?
hell I don't really know.. I just thought I heard someone say that one time
Old Nov 4, 2004 | 02:19 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yea diesel engines have higher comp. ratios than gasoline engines. gas engines are spark ignition engines and diesel engines ar compression ignition egines which means gas engines ignite the fuel via a spark and diesel engines ignite the fuel via compression. thats all i know.
Old Nov 4, 2004 | 02:22 PM
DB7 2.0's Avatar
DB7 2.0
Banned
i dunno, but your name still reads to me as "joe poonani"
clickwir's Avatar
clickwir
well then as long as it doesn't ignite before the spark then it's ok I guess.
I would assume the spark would ignite it. but I don't know for sure.
Old Nov 4, 2004 | 02:26 PM
DakarM's Avatar
DakarM
it would cause some damage. It wouldn't combust before the spark because gas engine don't compress the mixture to a high enough pressure.
diesels are usually 20:1 or higher I believe. However, it would kill your fuel system probably all the seals from the tank to injectors.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Nov 4, 2004 | 02:28 PM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
engine won't run, or if it does, it will run VERY poorly. if this is done, you will need to flush the entire fuel system. most likely damaged will be fuel injectors..
Old Nov 4, 2004 | 02:47 PM
Samson's Avatar
Samson
chris is the devil
how bout gasoline in a diesel engine
