question
Old Oct 19, 2004 | 04:42 PM
ED9man's Avatar
ED9man
driver
Default question
JDM SiRI B16a
Does VTEC engage in neutral?
Does the fuel cut off kick in earlier in neutral?
Or is it the goddamn spool solenoid valve self diagnostic code?
I'm going to drive it for the first time tommorow, but could a bad MAP sensor actuating a safe mode?
It's always something stupid.
Old Oct 19, 2004 | 04:43 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Originally Posted by ED9man
JDM SiRI B16a
No
No
Possibly
Old Oct 19, 2004 | 04:45 PM
ED9man's Avatar
ED9man
driver
lovely
I'm starting to hate this project because I'm out of money.
Old Oct 19, 2004 | 04:55 PM
ED9man's Avatar
ED9man
driver
what about the MAP sensor code?
Old Oct 19, 2004 | 04:56 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Check your Haynes manual or your Chiltons manual.
Old Oct 19, 2004 | 05:16 PM
ED9man's Avatar
ED9man
driver
it doesn't say anything about changing the way it runs sue to a code, just what it means and how to troubleshoot.
Old Oct 19, 2004 | 05:28 PM
dubcac's Avatar
dubcac
I
A map sensor code could be a bad map sensor, or bad wiring. It should cause it to run in limp mode, so you won't get vtec.
Old Oct 19, 2004 | 06:05 PM
ED9man's Avatar
ED9man
driver
thanks
I know my MAP sensor is bad, this spool solenoid problem isn't good either though.
I'm going to take it apart and make sure it's in good shape and hope it works.
My wiring is good on the sensor because I checked the connection between the plug and the negative battery terminal and it was good.
