Timing belt change
Old Oct 15, 2004 | 06:36 PM
ED9man's Avatar
ED9man
driver
Default Timing belt change
can I just mark the cam pulleys and crank and put the new one on the same as the old one or do I have to figure out how to get it to TDC?
Old Oct 15, 2004 | 06:40 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
there are 2 marks to note that from what i remember
Old Oct 16, 2004 | 05:19 AM
g2tegls's Avatar
g2tegls
MR, ftw
Yes you can. I did the exact same thing when I changed mine and used a white out pen to mark the belt and gears/pulley.
Old Oct 16, 2004 | 10:14 AM
dubcac's Avatar
dubcac
I
I would personally set everything to TDC. You might have to finagle the cam gears a little bit to get the belt over. Getting it to TDC is easy. Line the white mark on the crank pulley with the line on the block. Also, the cam gears have small dash arrows on the edge of the gear that will point at each other at TDC.
