PC overheating issues
Originally Posted by Skad
As does mine
w000t!
P4 2.66GHZ@3.00GHZ - SLK947U + Delta FFB0912EHE
CPU: 29@idle - 34@full load [fold]
Case: 28@idle - 32@full load
MSI GF4 Ti4200 128MB 8x AGP - 315/621
2x512 DDR333 Dual Channel
I had lots lots of fans. But that temps or yours is normal I think. What's your ambient temp? mine is ~70-75 F.
TRy to lap the heatsink and use artic silver 5. It should drop your temp a lot (5-10* C). Also, I don't like thermaltake HS, try to get some thermalright, they really do work. Try the ducting method too, it drops my temp like ~3-5 degrees celcius.
I would check to see if you have any programs running in the background;
ie did you install any new antivirus's etc.
Maybe check if you have any spyware...
I know that if I open a few programs, the temperature rises 3-5 degrees.
What motherboard are you running and what are you using to read the temps?
Check to see if fan filters are clogged.
I honestly think adding another 80mm would help much.
And lastly, the weather outside and in the room also affect the temps...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
I have a hardware monitor that came with my Soyo motherboard. I'm going to get a couple more fans and use some of that Arctic Silver paste sitting in my drawer. Then I may get naughty with the bios. :rick:
my old comp used to overheat and then shut itself down :eek3:
turns out the heatsink to the processor was clouded with dust :chuckles:
i cleaned it out the problem was solved....at least i think it was. i sold the computer a few days later :rick:
Originally Posted by White[Pony]
could just be the ambient temperature rising. That's why mine is running hot right now.
it's pretty warm in my room and my CPU is pretty hot.
I had to go down on my OC this summer...
AS5 is good, but use sparingly.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
