help me build a computer II.V
Old May 27, 2004 | 10:33 AM
Grifter's Avatar
Grifter
Default help me build a computer II.V
i have no idea what mobos are good
can yall suggest one for this cpu
http://www.newegg.com/app/viewProduc...116-171&depa=0
i might be leaning towards asus
i wont need onboard: vid card, nic, sound card
also when i have a vid card with video outs will it detect the tv like a monitor?
will it resize the resulotion like changing monitor sizes?
Old May 27, 2004 | 10:37 AM
randomtask77's Avatar
randomtask77
Wanderer
I got this one from newegg. I have no complaints with it. Wish I could answer your video question (I just have mine hooked up to my 19" monitor). h:
http://www.newegg.com/app/viewproduc...127-155&DEPA=0
Old May 27, 2004 | 10:57 AM
spanky's Avatar
spanky
I go duffy on dem bitches
asus > *
with the video out you'll use the software to choose the res that it displays on teh TV and it will be separate from the monitor
Old May 27, 2004 | 11:14 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Here's mine (ASUS P4P800 Deluxe)
http://www.newegg.com/app/ViewProduc...131-492&depa=1
It's an 865PE chipset an ASUS is the one who cracked Intel's PAT (a performance enhanced mode they only offically offered on the 875 chipsets but was built into but not turned on in the 865 chipsets). In most of the performance benchmarks I read when I bought mine (about a year ago now) this was on top or close and definately one of the price leaders. Has 2 SATA ports capable of RAID 0 and 1, a VIA raid controller for the PATA ports, built in Gigabit ethernet (thorugh the PCI bus though, so limited by the PCI's bandwidth), build in Firewire (1 rear, 1 MB header), USB 2.0 (4 rear, 4 header), has decent integraded audio but I upgraded to an Audigy 2 ZS with mine.
I'm very happy with it, stable and it's running pretty much non stop. Only issues I had was finding the nessicary RAID drivers on the CD to allow XP's installer to see the SATA RAID (they were on there, I just had to really scour the book to find where) and I had some instability with my Radeon 9800 Pro until I flashed to the newest BIOS and it's been stable since.
My 9800 Pro acts like 2 seperate display adaptors (right click on the desktop and go to properties then settings, you can decide between 2 displays. 1 is my 19" NEC monitor and 2 is just empty but you could probably set it up to use that as the primary display and set the resolution down to like 640x480 for a TV. I'd go with a real monitor unless your planning to build a PVR box or something?
Old May 27, 2004 | 11:34 AM
Nelson's Avatar
Nelson
Administrator
I don't suggest the Prescott (3.0E) chip if you plan on overclocking or pushing it.
I have had alot of success with the Northwood (3.0C), pushing it to 4.0ghz. You can go 3.6ghz straight from the box.
As far as mobo's... I run the Abit IC7-Max3. This is one nice board. I have been a die hard Asus user, but the Abit outperforms the Asus (P4P800E Deluxe)... I was deciding between the two. My friends had the Asus and got rid of them in favor of the IC7.
Andy has it down pact about the ATI 9800Pro...
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 27, 2004 | 12:00 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
yep, Abit IC7-Max3 is a good board. didn't i suggest that one chuckster?
Old May 27, 2004 | 12:06 PM
Nelson's Avatar
Nelson
Administrator
My only complaint on the Max3 is that the 2 fans included are a bit noisy, but if you have other fans going on, then it won't really be noticeable. I took out my northbridge fan and lowered the RPM's on the QTES fan.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 27, 2004 | 02:15 PM
Grifter's Avatar
Grifter
that abit board is more attractive in appearance but its $80 more
also anyone heared of silenx psu?
it was highly recommended to me but quite expensive
Old May 27, 2004 | 03:49 PM
Nelson's Avatar
Nelson
Administrator
If you don't need most of the extra features, the regular IC7 is fine.
As for Silenx, they are known for their quiet fans. They are pretty good, but costly. Enermax is a pretty good alternative. How many watts are you looking for?
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 27, 2004 | 04:40 PM
Grifter's Avatar
Grifter
~450/
