Computer Gurus...need some help
Old May 22, 2004 | 02:50 PM
RB's Avatar
RB
snitches get stitches
Default Computer Gurus...need some help
I'm playing around with some old hard drives, and I want to install one as a slave drive onto my mom's computer. Her comp, which I will be using as the main drive, is running win98se. The slave drive that I've installed has XP Pro. I have the pin settings correct on both hard drives, and the slave drive is now readable under my computer, but not openable. When I try and open it, it gives me this error: "D:/ is not accessable. A device attached to the system is not functioning." The main drive is functioning as normal.
Does this mean that the MAIN drive has to be running XP pro as well? My dad said they they are reverse compatable, meaning if the main drive had XP and the slave had 98 that it would work. Unfortunately he thinks that it isn't forward compatable.
Can anyone clear this up for me?
Old May 22, 2004 | 02:52 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
If your XP is formatted as NTFS and the 98 is setup on a FAT32 system then you are going to have some problems
Old May 22, 2004 | 02:54 PM
RB's Avatar
RB
I'm almost positive that both are FAT32.
Old May 22, 2004 | 03:00 PM
Bl@ck's Avatar
Bl@ck
Sinner
can you format it? or do you not want to format for some reason?
Old May 22, 2004 | 03:11 PM
spanky's Avatar
spanky
I go duffy on dem bitches
use a win98 boot disk and use fdisk to verify the file system being used. it sounds like the xp hdd is indeed ntfs
Old May 22, 2004 | 03:14 PM
b00gers's Avatar
b00gers
yea...chances are XP is using ntfs. why dont you format the slave drive. the OS is just taking up room h:
Old May 22, 2004 | 03:15 PM
RB's Avatar
RB
The problem is that its not letting me access the slave drive...BUT, when I right click and access properties, it says the file system is "FAT". It doesn't say fat32 though...
Old May 22, 2004 | 03:16 PM
RB's Avatar
RB
also, I don't want to format the drive because there is stuff on the slave drive that I want.
Old May 22, 2004 | 03:17 PM
b00gers's Avatar
b00gers
can you format the drive? or is that not an option?
edit...a lil late h:
Old May 22, 2004 | 03:19 PM
RB's Avatar
RB
Well, I've got an XP cd that I can install on the main drive, so that both systems will be running XP, the only problem is that the 25 digit code to install XP is in Corvallis and my dumb ex couldn't find the XP box in my room, so I'd have to wait til next week to install it h:. I contemplated changing the pin arrangement on the drives and them making the XP drive as the main, but the bios of the computer that I'm running it on is set for 98 SE, so it'd probably crash.
