Grrrr @ EMI
Old Apr 24, 2004 | 10:33 PM
Baget's Avatar
Baget
All Show and No Go!
Default Grrrr @ EMI
GRRRRRR so i just spent like 4 hours installing my new fronts and finally using all 4 channels of my amp... i get it all hooked up and working to perfection!.... until i turned my car on i get some really wierd ass EMI that goes in tune with my engine if i rev it but if i turn volume to 0 it doesn't do it.
this would be EMI i am assuming? i have all wires (RCA and speaker wires to and from amp) running down the right side but i have to have the front left running up the left side of the car. but also the interfence noise is only in the back if i move it to all front i don't get it.
why am i stupid?!?!
Old Apr 24, 2004 | 11:53 PM
Baget's Avatar
Baget
All Show and No Go!
nobody knows about emi eh? poop
Old Apr 25, 2004 | 12:27 AM
White[Pony]'s Avatar
White[Pony]
For relaxing times...
maybe everything's not shielded properly? :dunno:
Old Apr 25, 2004 | 06:44 AM
Baget's Avatar
Baget
All Show and No Go!
its 2 0 guage wires... how would i go about shielding those?
Old Apr 25, 2004 | 07:16 AM
Black2KGSR's Avatar
Black2KGSR
The power cable isn't running down the same side as your patch (RCA) cables, is it?
Make sure you have a good ground, too.
Old Apr 25, 2004 | 08:19 AM
Baget's Avatar
Baget
All Show and No Go!
well my deck is ghetto shit only has RCA outs for subs. so i left the rear wires in place and ran new front wires back to my amp along the right side with my RCA wires. So there is a total of 3 sets of wires and 1 set of rca on the right and 1 set of wires running down the left with 2 0 guage power wires..
i think it might be a loose connection possibly though? if that could do it.. i'd figure if it was EMI it'd be hitting the front speakers not the rear...
Old Apr 25, 2004 | 08:28 AM
Nightshade's Avatar
Nightshade
un-Touch'd krew
:chuckles:
And there would be part of your problem
Actually I would guess its because you are trying to overwork the amp and the ground may not be sufficient for tha amount of power you are trying to draw from it. In this case it will cause an EMI signal or possibly alternator whine depending on where the ground is located.
Old Apr 25, 2004 | 04:01 PM
Baget's Avatar
Baget
All Show and No Go!
well i have 0 guage for all my grounds sub amp is by itself and i have the cap/400 watt amp ground on the same one. it was just the left rear speaker for some reason so now its unplugged and i'm just running fronts only. problem was amp i guess on a stupid side my right sub went out also
Jessica
Feb 5, 2004 04:02 PM
RSXxXMeg82
Jan 12, 2004 08:00 AM
Nightshade
Nov 1, 2003 07:51 PM
The G2 Racer
92+ Civic/EL & Del Sol
4
May 4, 2003 10:20 AM
