MAINT REQD light keeps flashing, NEED HELP!!
Old Apr 3, 2004 | 12:18 AM
EJcivic02's Avatar
EJcivic02
I talk Before I think
Default MAINT REQD light keeps flashing, NEED HELP!!
just today when i started up my car for lunch, i noticed that after it started and was idling, my "maint reqd" light started flashing. I turned off the car and turned it back on and the same thing occured, totaling with 10 flashes everytime. Now whenever i start up my car, it does the same exact thing, flashing 10 times. When i bought the car a month ago, i changed out the basic tune-up things (fuel filt, oil, oil filt, thermo... ect) . What do you think could be the problem and has anyone seen this? new to integras, so im kinda clueless.
-its a 94 integra RS btw ThanksInAdvance
Old Apr 3, 2004 | 12:21 AM
antarius's Avatar
antarius
Large Member
Man, use the search button.
Anyway, under your steering wheel right at the point where your lower dash ends, there's a small rectangular button.
Put the key in (all the way off), press and hold the button in, while holding the button in turn the key to the accessory mode and wait for the light to flash and go off.
Then turn the key to off, and when you turn your key on from then on - it will be gone.
Old Apr 3, 2004 | 12:23 AM
EJcivic02's Avatar
EJcivic02
ive been here long enough to know what the search button is, i just didnt feel like using it this time. Thanks for the help though
EDIT: was also looking for an answer as to why this happened too.
Old Apr 3, 2004 | 12:48 AM
Bl@ck's Avatar
Bl@ck
Sinner
it's factory set to go on after you hit so many miles as a reminder to service the vehicle.
Old Apr 3, 2004 | 07:11 AM
b00gers's Avatar
b00gers
searching would have given you the answer to WHY also.
like black said, its set by the factory to remind to you to change your oil. i believe it comes on every 7500 miles in the integras.
Old Apr 3, 2004 | 08:13 AM
DB7 2.0's Avatar
DB7 2.0
Banned
OMG!!!!!!! :eek3: it turned on?!?!?!?!?!?! :eek3: :eek3:
Old Apr 3, 2004 | 03:50 PM
AP2's Avatar
AP2
Moderator Alumni
When it's flashing like that, your engine's likely doing some nasty misfires.
Old Apr 3, 2004 | 04:05 PM
Bl@ck's Avatar
Bl@ck
Sinner
maintenance required, not check engine:doh:
Old Apr 3, 2004 | 04:09 PM
AcuraFanatic's Avatar
AcuraFanatic
olong:
Old Apr 3, 2004 | 06:56 PM
AP2's Avatar
AP2
Moderator Alumni
Ooops, I tend to read shit too fast.
